fiberglass resin not drying
MikeHusain
Copper - Posts: 139
Posted: June 15, 2004 at 10:00 AM / IP Logged
i was wondering if anyone new what i am doing wrong.  I am trying to make some kick pods and when i mix the resin and hardener and place the mat inside it and lay it down, it does not dry.  it takes about a week to dry and then it still feels sticky.  I tried mixing more resin hardener to speed up the drying process but it still doesnt work.  What am I doing wrong?  Thanks......
suicide
Member - Posts: 14
Posted: June 15, 2004 at 10:53 AM / IP Logged
HEAT!!! is the key!!!
If u have a Heat gun... not a hair dryer..  that would speed it up... if u don't have that try leaving it in the sun...  that should cure the resin...  and if u want . try adding more hardner.. over the kickpods.. that might speed it up.. but try the heat first...
 - suicide
pureRF
Silver - Posts: 619
Posted: June 15, 2004 at 2:07 PM / IP Logged
How would a heat gun and sun work but not a hairdryer? A hair dryer will work ive used it numerous times. You could try adding another layer of mat with resin with a lot of hardener in it.
dream it, build it, fiberglass it
auex
Platinum - Posts: 5,041
Posted: June 15, 2004 at 6:56 PM / IP Logged
What kind of resin are you using, specifically?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
rcstdad
Member - Posts: 9
Posted: June 16, 2004 at 7:10 AM / IP Logged
Make sure you are mixing the components together good too.
jaymes
Copper - Posts: 47
Posted: June 17, 2004 at 8:52 PM / IP Logged
add even more hardener.. but not too much.. how cold is the area u are working in? i have actually added too much hardener and it wasnt pretty. practice makes perfect
mikedawg
Copper - Posts: 142
Posted: June 17, 2004 at 10:45 PM / IP Logged
you gotta give it a lot of air circulation. i dont know why but i have heard that a hair dryer wont work but a heat gun will. not sure if thats correct, ive never tried either of them. youre probably using polyester instead of epoxy resin. ive had that sticky problem too when i use the polyester.
always looking for new info and willing to give it
vk51
Member - Posts: 7
Posted: June 21, 2004 at 10:42 AM / IP Logged
I have had a couple experiences of resin taking longer to dry than normal.  I have found the reason to be from an old batch of resin.  If it has been on the shelf for too long, it just doesn't work like it is supposed to.
CarAudioHelp
Copper - Posts: 198
Posted: June 29, 2004 at 4:05 PM / IP Logged
It sounds like you're using cheap resin. I had the same problem when I was trying to use a batch of non-spec resin. Lesson learned. Use the good resin.
Your project will dry eventually but you'll want to get better resin for future work.
