I got a question about Subs
e40water
Member - Posts: 47
Posted: June 22, 2004 at 2:28 PM / IP Logged
Heres my Question I am running 360 watt JBL amp 4 channel, I have 1 15inch running now, I want to get rid of the 15 add 2 10's, 1&2  channels are running my 6x9's, So all the got 3&4 left, So with my 2 10's could I run them parrell from 1 10 to the other 10, ?
e4
furflier
Copper - Posts: 236
Posted: June 22, 2004 at 5:33 PM / IP Logged
If you get 2 8ohm subs you can bridge channels 3&4. If you get 2 4ohm you need to run them on each indepedent channel.
e40water
Member - Posts: 47
Posted: June 23, 2004 at 2:37 AM / IP Logged
I am planning to get 2 10's sony XSL101P5 10" rated 4ohms, I want to run 4 ohm single voice coil woofers at 2 ohm's, Would I still be able to have the amp bridged still? Ive a JBL BP300.1 4 channel amp. Or I wont be able to bridge 3/4 channels?
e4
Mystikal_Dream
Member - Posts: 9
Posted: June 23, 2004 at 4:55 AM / IP Logged
If your amp can handle 2 ohms with channels 3 and 4 bridged, your ok (Check your spec sheet). Be sure to check the specs, becuase if your amp cannot handle a 2 ohm load when bridged you will burn it up. If it cant, then you will have to connect each sub to a single channel, or get 2 8 ohm 10" subs.
Probe GT-Bepro!
e40water
Member - Posts: 47
Posted: June 23, 2004 at 1:52 PM / IP Logged
ok well its teling me its telling me at 4 ohms bridged 360W  X1 power output , Mininium speaker impedance 2ohm / Power output 2ohms 180W X2 . I just looked on the JBl site, I dont have my manual anymore, any other ideas?
e4
customsuburb
Gold - Posts: 1,813
Posted: June 23, 2004 at 2:39 PM / IP Logged
If those are 4 ohm DVC subs then wire one on each channel (like 3 and 4). Do you have to buy sony subs though?
forbidden
Platinum - Posts: 5,354
Posted: June 23, 2004 at 4:39 PM / IP Logged
Find yourself some different subs that are either single 8 ohm coils or dual 4 ohm coils. Then the amp can be bridged and operated safely to drive two subs.
