96 Chev PU OEM Power Locks?
mostanything
Posted: June 29, 2004 at 4:25 PM / IP Logged
I'm fixing up a plain 96 C1500 and have installed the factory dash harness for PW, PM, & PL.  every thing works except the power locks.  The Haynes electrical diagram shows a relay on some models.  Where should this relay go and what does it plug into?  I also received the keyless module with the harness but there's nothing to plug it into.  the lock motors work when voltage is applied directly.  Any help is greatly appreciated.
Thanks,
Mostanything
Mostanything can be fixed
draasch
Gold - Posts: 2,172
Posted: June 29, 2004 at 5:37 PM / IP Logged
Power Lock L BLUE DRIVER KICK SEE NOTES ** #203
Power Unlock WHITE PANEL BELOW #202
** Without OEM Keyless See Note #203. With OEM Keyless See Note #202. #203- See Reversal Rest At Ground Door Lock Diagram. #202- See Positive Pulse Door Lock Diagram.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
mostanything
Posted: June 30, 2004 at 8:21 AM / IP Logged
Ok, where do I find the notes 202 & 203 that are referenced?
draasch
Gold - Posts: 2,172
Posted: June 30, 2004 at 9:22 AM / IP Logged
mostanything
Posted: June 30, 2004 at 4:21 PM / IP Logged
Thanks, that helps.
Mostanything
Friday, February 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
