which is better?
Xplorer
Copper - Posts: 69
Posted: June 30, 2004 at 9:36 PM / IP Logged
Hey,
     I am about to install a couple of 12's in a sealed enclosure and was wondering how to run my wiring to the 2 subs. I was gonna wire the subs in parallel (4Ohms each <-> 2Ohm load)and wanted to know if i should make a small hole in the back of the box , run the speaker wire , then hot glue gun it so it is air tight OR should i just buy a terminal , install the terminal to the back of the box , and then connect the wire to that. Does it matter which way i do it? Also does it matter what gauge wire i use?
Peace
dangerranger96
Copper - Posts: 163
Posted: July 01, 2004 at 12:06 AM / IP Logged
use some silicone caulk instead of hot glue it seals better
CarAudioHelp
Copper - Posts: 198
Posted: July 03, 2004 at 12:35 PM / IP Logged
Spend a buck and get the terminal cup or a nice set of binding posts. Much more professional and reliable.
