02 yukon dome light, will this work
ps1k0
Posted: June 30, 2004 at 11:59 PM / IP Logged
I have an 02 yukon, and i put a viper 791xv alarm in it.
the problem is, when i turn the key off, the dome light supervision kicks in and shoots power to the dome light(like it's supposed to), but it shuts off the RAP (retained accessory power) and i can't put my windows up.
I am planning on putting this relay setup in to keep the RAP going, but not turn on the dome (through alarm)when i turn the key off, but yet let the dome turn on when i disarm the alarm.
i figure this should do it, atleast it looks good on paper.  mostly i wanted a second opinion b4 i went through with it.  any input or modifications are more than appreciated.
02 yukon dome light, will this work -- posted image.
The Louder it is...
..The More I Like It!!!.
ps1k0
Posted: July 01, 2004 at 12:03 AM / IP Logged
seems to have not shown the pic so here it is again
The Louder it is...
auex
Platinum - Posts: 5,041
Posted: July 01, 2004 at 3:19 PM / IP Logged
You have to include the file extension.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
auex
Posted: July 01, 2004 at 3:22 PM / IP Logged
How about wire a relay that will cut the domelight supervision while RAP is still on? Just basically: 85 ground or ground when off(like an ignition wire or something), 86 +RAP, 30 domelight supervision input, 87A domelight supervision output.
ps1k0
Posted: July 01, 2004 at 10:05 PM / IP Logged
ahh..
i didn't even think of that.
alot less relays used..
less bulk..
i like it..
thanks.
The Louder it is...
auex
Posted: July 01, 2004 at 10:39 PM / IP Logged
Not a problem.
Sunday, November 2, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
