RPM Guage only works intermittently
rtsam
Posted: July 05, 2004 at 4:29 PM / IP Logged
Hello everyone,
I installed a car starter over a year ago, and recently the rpm guage went haywire and jumped all over the place.
I removed the starter thinking that was the cause. Now the RPM guage only works after driving it about 7miles  or it doesn't work at all... has anyone ever heard of this happening? or have any idea what I could check.
I am thinking the coil might have been shorted.
Thanks for any help you can offer!
Shaun
jrilla
Gold - Posts: 1,498
Posted: July 11, 2004 at 9:00 PM / IP Logged
Is it a Honda? I had that happen on two different Honda Accords before but never knew what caused it.
J Rilla
Owner/Installer
rtsam
Posted: July 12, 2004 at 11:07 AM / IP Logged
Actually it is a 2003 Chevy Tracker,
I have heard maybe a faulty voltage regulator may cause it. But not sure.
Besprend
Member - Posts: 29
Posted: July 15, 2004 at 12:10 PM / IP Logged
I have experience a faulty car starter on a 86 lincoln Mark VI. It has the same problem. However, the car owner said when he took his car from the dealer it was just an alternator problem. When it was replaced everything else went smooth. That is according to the cars owner.
Sk8trcm
Posted: July 19, 2004 at 12:39 AM / IP Logged
i would have to agree with the voltage regulator being the culprit on that one RT.
Chris
rtsam
Posted: August 06, 2004 at 10:16 PM / IP Logged
Thanks for all the replys everyone....
I tested the voltage at the battery while running and the voltage seems fine....
could it still be a voltage regulator?... I am baffled on this one.
Shaun
Wednesday, May 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
