2004 GM HV Stereo
n2themix
Posted: July 12, 2004 at 8:08 AM / IP Logged
can this HUehicle dependency? be used outside of the vehicle or is there too much interconnectivity with the CPU and accesories to create an in vehicle dependency?
Dave
kgerry
Platinum - Posts: 3,455
Posted: July 12, 2004 at 10:05 AM / IP Logged
it wont power up outside of the vehicle...
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
n2themix
Posted: July 15, 2004 at 9:40 PM / IP Logged
is there any way to defeat this with wiring, harness splicing etc.
Dave
lspker
Silver - Posts: 503
Posted: July 15, 2004 at 9:50 PM / IP Logged
Some GM radio's require info on the data line to confirm they installed in the proper car.  Other are normal and don't require anything special to work, just the harness.
Beowulf31539
Posted: July 15, 2004 at 11:24 PM / IP Logged
So let's say you bypass the data line and connect your 12 volt acc. wire on a new head unit directly to the fuse box.  Will it affect anything else on the vehicle or does the data line need to be connected to factory radio at all times?
kgerry
Posted: July 16, 2004 at 10:00 AM / IP Logged
what exactly is the question?  whether you can use a factory HU from this vehicle outside the car? (no) or whether you can use another radio in this vehicle? (yes, with the proper data interfaces)
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
Beowulf31539
Posted: July 16, 2004 at 10:34 AM / IP Logged
What exactly is the information on the data line of an HV Stereo?  I know the door chimes, but what else?  I'm asking because my brother-in-law wants to hook his old cd player(out of the truck he wrecked) up in his new truck.  It's a pioneer or JVC, I'm not sure.  I know it's not HV.  He's wanting to bypass the data line if possible but I told him I didn't know what information was on that data line.  Any help would be appreciated.
Sunday, July 27, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
