cd stuck in cd player
Bigmaine
Member - Posts: 13
Posted: July 17, 2004 at 2:18 PM / IP Logged
wassup y'all, i was just wondering how do you get out a stuck cd without filing the opening.
harvey1959
Copper - Posts: 94
Posted: July 17, 2004 at 3:05 PM / IP Logged
We're talking car stereo ? Right!!  You probably will have to pull your deck from the dash and open the top of it and push the CD out.  Also you might be able to cut power to the radio and attach it again.  This may work like rebooting a computer and the disk may slide out on its own  Going the power route, you'll have to reset all your presets but it may work.  (Pull radio fuse).
Harv
kgerry
Platinum - Posts: 3,455
Posted: July 17, 2004 at 5:45 PM / IP Logged
if you can't isolate both radio fuses, just try to disconnect the battery for 15 minutes or so ( giving time for all the caps to discharge ) and reconnect it.... you may luck out and the disc will now eject like Harvey1959 suggested....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
stevdart
Platinum - Posts: 5,816
Posted: July 17, 2004 at 7:10 PM / IP Logged
Good sig line, kgerry.  The absolute truth.  There is the point where one has just enough knowledge to be dangerous...then comes the time when he has enough knowledge to be humble.
Bigmaine
Member - Posts: 13
Posted: July 18, 2004 at 2:29 AM / IP Logged
thanx for the help,  i'll let y'all know how it turns out.
Saturday, February 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
