3 - 10’s or 2 - 12’s?
MBZ oe
Silver - Posts: 385
Posted: July 25, 2004 at 7:52 PM / IP Logged
I have been running 3 10's for a few years and have been contemplating a system change lately because I need more BASS. Can 2 12's pound as hard or harder than 3 10's? Good subs like JL 6 or 7, MTX 8500 or 9500, Eclipse aluminum or titaniums, etc.
The easiest for me to get would be the 9500's.
I am extrememly disappointed with my new 8000 series 10's and retract my earlier praise of them. I was very satisfied with the old ones but my new ones suck. And the glue is bubbling out the front where the cone is together.
Anyone?
boom, boom, boom boom....
xtreamcc
Silver - Posts: 467
Posted: July 25, 2004 at 9:32 PM / IP Logged
u dont need more bass pursay, ur just going deft slowly and need to increase the volume output so it sounds good to you, I know the feeling. As far as 2 12's out bangin 3 10's, it all depends on the setup. 1 12" JL w7, will destroy 3 10" MTX8000 with the proper setup. The 8500 is basically just a longer throwing 8000 where as the 9500 is a redeigned 8500 with event longer, but much improved throw capabilities. They still cant touch the JL's in sound qualities at high volumes, but they can potentially out perform the JL's as I've stated in other posts, the 9500 is a damn good sub, it hits quite a bit louder than a JLw7, BUT, u turn the volume way up and u'll hear that distortion. Anyway, I'd say if u want something better than 3 8000's, go with a pair of 9500's or w6v2's and if u can swing it, get the w7's.
"Shiny chrome when used in conjunction with bikini models is particularly effective in inducing brain deficit disorder"
02 Jeep Grand Cherokee
Monster System on its way.
defective
Silver - Posts: 642
Posted: July 25, 2004 at 10:30 PM / IP Logged
hey, dont forget the Type-Xs will be out soon........    Go Alpine......
Ravendarat
Platinum - Posts: 2,806
Posted: July 26, 2004 at 9:25 AM / IP Logged
Actually the 9500 was out 8 months before the launch of the 800 so saying it is a redesigned 8500 isnt quite true being the 9500 was develpoed and released first. I am sure if you power a set of 9500's properly you will be happy with the output
defective
Silver - Posts: 642
Posted: July 26, 2004 at 9:49 AM / IP Logged
damn straight.   If  you power some 9500s right, you might die. 3 - 10’s or 2 - 12’s? -- posted image.
MBZ oe
Silver - Posts: 385
Posted: July 26, 2004 at 11:53 AM / IP Logged
I am currently powering the three 8000 series off of a 1200.1 kicker that was tested to put out 1550 watts at 1 ohm. I am running it at 1.3 ohms.
I have been contemplating adding a second 1200.1 or a Phoenix Gold Octane R 30.0:0. I will probably switch to phoenix gold amps since I can get nearly 3000 watts at 2 ohms, out of 1 unit.
How do the w6v2's compare to the 9500's. I need it REALLY LOUD without distortion.
Also, the entire car is multi-layered with dynamat x-treme so there are no rattles which really makes a sub shine or not, since there are no rattles to simulate the bass.
I can get 2 w6v2's for $600, 2 9500's for $650, or 2 w7's for $900. The w7's would probably need a huge box too, right? I've got  about 3.5-4 cu ft  for enclosure volume.
Ravendarat
Posted: July 26, 2004 at 3:01 PM / IP Logged
The 9500's will be louder and the W7's should sound cleaner so whats more important to you.
94legend
Silver - Posts: 237
Posted: July 26, 2004 at 3:12 PM / IP Logged
94legend
Silver - Posts: 237
Posted: July 26, 2004 at 3:15 PM / IP Logged
forbidden
Platinum - Posts: 5,354
Posted: July 26, 2004 at 3:46 PM / IP Logged
What, no pic of the Titanium Eclipse.  Ohhhh, the camera battery died right when the picture was about to be taken, I see now. I would consider this driver as well. All 3 are mighty fine.
