02 Voyager
meh66
Copper - Posts: 266
Posted: July 26, 2004 at 11:20 AM / IP Logged
Ok,
I have read many post on this alarm and I know I have to put the 180 OHM resistor on a relay and then connect to the second starter wire. However, my friend is now complaining about something else. She said when she turns the car on, her wipers and window sprayer comes on. I am really confused because when I left the car it was not doing that. Hwoever, I do not think it was doing it before I installed the alarm. Can some one provide some assistance. All I would like to do is get the car back to normal. Thanks
MEH66
"Car Performance and Mobile Electronic Enthusiats"
sparkie
Platinum - Posts: 2,061
Posted: July 26, 2004 at 3:44 PM / IP Logged
If you have used a negative out when running wire to activate more than one relay, you need to diode isolate it if there is more than one circuit running off of it. you may be getting a feedback problem through the coils of the relays if you haven't done this. This can accidentely cause circuits to receive power when they shouldn't. Unplug all your relays and see if the problem goes away.
sparky
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
