Dual 2ohm into 2ohms
MBZ oe
Silver - Posts: 385
Posted: July 31, 2004 at 2:21 PM / IP Logged
I was wondering how to get 2 ohms out of a dual 2ohm sub? The brahma says you can wire it for 1/2/4ohms. I would like to get 2 ohms out of each sub and the run them parallel for 1 ohm.
Angel
boom, boom, boom boom....
stevdart
Platinum - Posts: 5,816
Posted: July 31, 2004 at 3:46 PM / IP Logged
You can't.  The Adire site is giving possible impedances for multiple subs.  If you have two 2 ohm DVC's, wire them each in series for 4 ohms, then parallel for a 2 ohm load on the amp.
Dual 2ohm into 2ohms -- posted image.
MBZ oe
Silver - Posts: 385
Posted: July 31, 2004 at 4:22 PM / IP Logged
Thanks Steve
I couldn't think of any way that it was possible.
haemphyst
Platinum - Posts: 5,059
Posted: August 02, 2004 at 8:54 AM / IP Logged
Actually, it CAN be done with a single driver. If the VCs are wired in series, that gives you one 4 ohm load. If you wire the VCs, one to each channel of a STEREO amp, that presents a 2 ohm load, and if you wire the VCs in parallel, that will give you one 1 ohm option.
MBZ oe
Silver - Posts: 385
Posted: August 02, 2004 at 2:46 PM / IP Logged
I have only one 1200.1 mono amp right now. When I get the second amp I will be wiring each sub for 1 ohm.
I was just confused about the brahma website saying you could wire the dual 2 ohm sub for 1/2/4 ohms. But thats not what the website means as explained to me by Stevedart above.
>Actually, it CAN be done with a single driver. If the VCs are wired in series, that gives you one 4 ohm load. If you wire the >VCs, one to each channel of a STEREO amp, that presents a 2 ohm load, and if you wire the VCs in parallel, that will >give you one 1 ohm option.
___________________________________________
94legend
Silver - Posts: 237
Posted: August 02, 2004 at 4:08 PM / IP Logged
And when you do get a second amp You'll be using a distroblock with a crossover right?
The amp will be  a mono amp i assume?
or how are you going to split the RCA and Remote wire?
Do you have a diagram or can you explain how you will run the wire. Because i could not think of any way .
MBZ oe
Silver - Posts: 385
Posted: August 02, 2004 at 5:09 PM / IP Logged
The second amp will be an identical 1200.1 mono kicker. I could use the amp strapping circuit to connect them both together, but I will probably run each seperately to be in stereo.
For dist block, I don't need it because I have 2 runs of 0/1 ga  and a run of 8ga for my 300.4 that runs my mids and tweets.  I will be adding another run of 0/1ga for full length ground to lower resistance.
For RCA I have 3 RCA's running to rear Front/Rear/Sub and the Kicker has a preamp output to jump a short RCA to the second 1200.1.
Remote wire will have a relay since I will have 3 amps instead of 2. It would probably work without, but I'd rather do it right.
For Crossover, I always use amps onboard x-overs. Works fine for me.
Here is what it looks like now:Dual 2ohm into 2ohms -- posted image.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
