4 runner power wire
nuclearur
Member - Posts: 16
Posted: August 05, 2004 at 12:29 PM / IP Logged
i'm redoing a system of one of my friends and i was wondering where the best place was in the firewall to run a 4ga wire..i doubt there is a hole big enough already to run it i was just curious to know where a good place would be. ohh ya the car is a 2003 4runner
kgerry
Platinum - Posts: 3,455
Posted: August 05, 2004 at 12:33 PM / IP Logged
look for an existing rubber boot or filler plug... you'll probably find one above and behind the gas pedal area... if not drill a hole and use a snap in grommet before you run your wire through it....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
94legend
Silver - Posts: 237
Posted: August 05, 2004 at 1:27 PM / IP Logged
kgerry is right
There should be a rubber boot or rubber filler plug,  if its not located near the foot pedal there should be one in the center, you should be able to remove it with a screw driver,
is the battery located on the passenger or the driver side?
once the rubber is romoved there should be a hole, if its not big enough drill right into until its bigg enough and insert a grommet.  Don't want your power wire to catch on fire!
nuclearur
Member - Posts: 16
Posted: August 05, 2004 at 2:30 PM / IP Logged
thanks kgeryy and 94legend..the battery is located on the drivers side
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
