tach hook up
aSmartAzz4u420
Posted: September 16, 2002 at 1:26 PM / IP Logged
I need to hook up a tach in a 1999 Ford Ranger 2wd 2.5L 4 cylinder-i know about the ground, the lights connections and the 12volt connection, but i need to know what and where the ignition coil is that i'm supposed to tie the green wire into! thanks
Platinum - Posts: 12,488
Posted: September 16, 2002 at 6:06 PM / IP Logged
  TACHOMETER----------tan/white ---------
The ignition coil is located near the center of the motor on all models.
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
