95 Legend, Autopage Problems
jigga225
Member - Posts: 6
Posted: August 17, 2004 at 9:50 PM / IP Logged
Hello,
I'm attempting to install the Autopage RD-850LCD. I've installed many alarms before.
The problem I'm having with this one is the LED staying on, even when I unplug all the harnesses, exept the power 5-pin harness.
It won't go into RPM learning mode, or any of the modes where i can program things. And that darn LED never goes off!
I've checked my connections? Could the unit be bad? It is brand new...
jigga225
Member - Posts: 6
Posted: August 18, 2004 at 8:28 AM / IP Logged
ok i've determined that it's stuck in Valet mode. Becase of the "Zzzz" on theemote. the constant LED, and the only functions that work are the unlock/parking light flash.
Any suggestions?
stamper
Member - Posts: 8
Posted: August 18, 2004 at 10:34 AM / IP Logged
Look on page 9 or your OPERATION MANUAL for the 850 LCD and it will tell you how to exit valet mode.  If this does not work, call 800-262-2527, ext. 461.  This is Autopage tech support.  Good luck.
Stamper
