chevy truck 2nd ign. wire key turn on
dudek38
Copper - Posts: 250
Posted: August 17, 2004 at 11:43 PM / IP Logged
i did a system on an 04 chevy truck. i used metra's wire harness and ran a seperate ign wire to the fuse panel. my customers wanting the stereo to turn on with the key turned back(accy.). i just don't know what to do. do i have to go into the steering column? are other installers doing the same thing i did. maybe thats just the way it is? i cant recall if new chevy stock radios turn on with the key turned back.
owner of
Motion Marine & Car Audio
the florida keys
kkeeni
Member - Posts: 20
Posted: August 18, 2004 at 12:06 AM / IP Logged
the easiest way is to catch the accessory wire on the ignition harness, on the 04 chevy its should be an orange wire, but test to make sure with a ddm , and i usually fuse the wire also.
dudek38
Copper - Posts: 250
Posted: August 18, 2004 at 9:10 AM / IP Logged
ok, first i used the harness that gives the chime. i didnt have ign power, and didnt know that id have to run a seperate wire, so i switched the harness with the regular harness w/o chime. thats when i figured out the ign. wire problem. the harness worked, so i left it in. im wondering if the chime harness will give me power when the key is turned back???
owner of
the florida keys
kkeeni
Member - Posts: 20
Posted: August 18, 2004 at 9:34 PM / IP Logged
if you lost your door chime when you unplugged the factory radio , then you have to use the recation harness. it should come with a speaker for the door chime , but it will not give you ign. on the factory harness . 2000 and newer general motors products wil need an ign. or acc. wire ran to the radio.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
