8 ohm damage 4 ohm?
MBZ oe
Silver - Posts: 385
Posted: August 18, 2004 at 3:12 PM / IP Logged
Can you hook up a 4ohm sub to a home receiver thats rated at 8ohm to play at low volume for break in? Or would that somehow be bad for sub?
boom, boom, boom boom....
kgerry
Platinum - Posts: 3,455
Posted: August 18, 2004 at 3:49 PM / IP Logged
wouldnt be bad for the sub...it may be bad for the amp tho......
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
DYohn
Moderator - Posts: 10,741
Posted: August 18, 2004 at 4:14 PM / IP Logged
Kevin is right, that is in general not a good idea.  Home theatre amps are rated for 8-ohms (some for 6-ohms) minimum.  And there are a few home amps that can handle lower loads, but be sure to check the owners manual for your amplifier and do not load it below it's rated specs!
Wednesday, November 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
