2000 Windstar Keyless Entry
ccongo
Posted: September 19, 2002 at 1:28 AM / IP Logged
Can someone please tell me how power door locks for keyless entry should be wired on a 2000 Ford Windstar? Here's what I think is correct:
Unlock = light GREEN/ YELLOW
lock = light blue/orange
Type B negative system. Does this mean I connect ground across terminals terminals 87 on both relays and +12 volts to terminal 85 on one relay and 86 on the other? This way the relay will toggle ground upon activation?
Any insight is appreciated.
Thanks in advance
Chris
Platinum - Posts: 12,488
Posted: September 19, 2002 at 4:58 PM / IP Logged
  • LOCK------------lt blue/orange--------20 pin plug at FEM module
  • UNLOCK--------lt GREEN/ YELLOW-------20 pin plug at FEM module
  • The FEM module is located under the drivers side of the dash on the firewall.
The keyless entry should be a (-) output trigger system already so all you have to do is to attach the keyless entry wires directly to the target wires above .
ccongo
Posted: September 20, 2002 at 1:02 PM / IP Logged
Thanks, your information was very helpful!!
Chris
Posted: September 20, 2002 at 5:12 PM / IP Logged
No problemo.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
