Intellistart 4
CelicaGT
Member - Posts: 9
Posted: August 22, 2004 at 6:01 AM / IP Logged
I have just wired my Clifford avantguard 4, everything works properly except the intellistart. When I press the button to activate the intellistart, the lights flash three times, the engine starts, runs for 5 seconds and dies. The lights flashing three times apparently means a problem with the ignition wires, but they appear fine. Any suggestions on what might be causing this. Secondly the intellistarts heater/ ac cable has not been attached as there isn't a dedicated output on the ignition barrell (I think). Please help!!
Cheers
daniel2002p
Silver - Posts: 524
Posted: August 22, 2004 at 10:32 AM / IP Logged
Do you have the car info???
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
