1997 Camaro SS Factory Alarm Problem
Mattthew278
Copper - Posts: 52
Posted: August 23, 2004 at 9:12 PM / IP Logged
My friend just bought this car from a dealership and he's having a problem with the alarm.  He says when he arms the alarm with the transmitter, it arms normal.  About 5 seconds later the alarm goes off, as if the alarm was triggered.  He says he then hits the arm button again and then it arms, and has no problems.  Thanks in advance for any help.
matt
draasch
Gold - Posts: 2,172
Posted: August 23, 2004 at 9:17 PM / IP Logged
do you know for sure that it is a factory alarm????????
what does the transmitters look like???
is there a siren or does the horn honk???
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Mattthew278
Copper - Posts: 52
Posted: August 24, 2004 at 7:39 PM / IP Logged
I just talked to him and he said he's pretty sure it's a factory alarm.  He said that when it goes off the horn honks, and the lights flash.  Also, when he firsts arms it, the led inside starts flashing, one blink at a time.  After the alarm goes off, and he clicks to arm it again, the led starts flashing twice between pulses.
Mattthew278
Copper - Posts: 52
Posted: August 24, 2004 at 8:47 PM / IP Logged
He said it says GM on the Transmitter
draasch
Gold - Posts: 2,172
Posted: August 25, 2004 at 8:58 AM / IP Logged
ok, it might say gm on the transmitter, however the had add on units for factory keyless entry units so that you can turn it into an alarm.
with the problem that he is having, i kinda think its an add-on....have him look under the dash to see if there the brain is under there...if so, have him write down any info that he can find......then post your findings....
Good Luck
David
Ace Security
813-376-9778
Tampa
