2000 corolla prestige alarm
huntr24td
Member - Posts: 7
Posted: August 25, 2004 at 10:40 PM / IP Logged
i was wondering can i tap into the trunk pin wire located on the drivers side instead of using my hook pin which i used for the hood.???? thanks in advance
draasch
Gold - Posts: 2,172
Posted: August 25, 2004 at 10:58 PM / IP Logged
Dome Light RED / WHITE (-) IGNITION SWITCH HARNESS **
Trunk Pin Switch RED / WHITE (-) AT LIGHT IN TRUNK
you can try it....test it with a meter
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
huntr24td
Member - Posts: 7
Posted: August 26, 2004 at 5:10 AM / IP Logged
which wire from the alarm would i use?  would it be the same as the one for the hood pin?
draasch
Gold - Posts: 2,172
Posted: August 26, 2004 at 5:37 PM / IP Logged
no there should be another - trigger wire
Good Luck
David
Ace Security
813-376-9778
Tampa
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
