A/C diagram for 2000 Dodge Ram
Pachecris
Posted: September 20, 2002 at 3:49 AM / IP Logged
Hi there~
Can anyone help me locate a wiring diagram for a 2000 Dodge Ram 2500 pick up? Manual trans. I truely appreciate it. I'm new here. You guys are a Godsend. Thanks!
Christine
Platinum - Posts: 12,488
Posted: September 20, 2002 at 5:26 AM / IP Logged
|              12V|red and pink/black  |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|dk. blue            |+  |ignition harness            |
|  SECOND IGNITION|BLACK/ orange        |+  |ignition harness            |
|        ACCESSORY|BLACK/ white         |+  |ignition harness            |
|       POWER LOCK|ORANGE / purple *1    |5wi|in harness from             |
|     POWER UNLOCK|pink/purple *1      |5wi|drivers door                |
| PARKING LIGHTS +|BLACK / YELLOW        |   |drivers kick panel          |
|       HEADLIGHTS|lt. green *5        |-  |steering column             |
|     DOOR TRIGGER|yellow *2           |-  |drivers kick panel          |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|lt. GREEN/ orange    |*3 |harness from door           |
|       TACHOMETER|BLACK/ gray *4       |   |ignition coil               |
|       BRAKE WIRE|WHITE/ tan           |+  |at brake pedal switch       |
|     HORN TRIGGER|BLACK/ red           |-  |steering column             |
|           WIPERS|RED / blk & RED / yel   |+  |steering column             |
|  LF WINDOW UP/DN|lt. blue - white    |A  |drivers window switch       |
|  RF WINDOW UP/DN|brn/wht - pur/wht   |A  |harness from door           |
Notes:
Note : Diesel glow plug wire is a ORANGE / black(-) "see directfax document #1090", and the tach wire is a gray/black. Both wires are located on the center of the firewall. There are two black plugs, the wires are in the plug without the white insert. If using the org/blk for wait to start causes a shifting or cruise control problem then use a pulse timer relay instead, refer to directfax #1091 for wiring information.  *1 Keyless models use positive trigger for lock, and 5-wire for unlock. Can also find wires at the central timer module to the right side of the steering column, lock is ORANGE / green, unlock is pink/green.  *2 To avoid dome delay, use tan for the drivers door and BLACK/ lt. blue for the passenger door.  Both wires are located at the central timer module to the right side of the steering column.  Use both wires and diode isolate each.  *3 Factory disarm is a negative trigger through a 1.5K (1500) ohm resistor.   *4  Diesel tach wire is gray/black at the ECM on the passenger side firewall in connector C-1, pin 8  *5 This wire requires a high current negative, must use relay.
Tuesday, March 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
