What happend to my speaker?
goldfinger
Member - Posts: 38
Posted: August 29, 2004 at 8:25 PM / IP Logged
I noticed after going down a dirt road my right front speaker was making a noise.  I assumed I jarred something loose and it was just something viberating in the door panel.  I took the door panel off and found that one of the wires had pulled out of the connector and was touching, but not well connected.  I thought I could simply re-connect the wire and fix my problem....... not so.
I took the speaker out of the door, held it in my and and it's clearly static.  I looked closer at the tweeter and it's got a crack right down the middle.  What happend to my speaker? -- posted image.  Could this be caused by the loose connection or the dirt road?  Or is it a factory defect?  The speakers are Blaupunkt PCxT462 (2-way transparent 4x6's).  I bought Blaupunkt's all the way around and I've only had them since the end of January.  If this starts happening with my 6x9's I will not be happy.
Anyone know what might cause this?  Is it worth trying to get a replacement under warranty or just buy a new set?
clftn
Member - Posts: 9
Posted: August 29, 2004 at 8:33 PM / IP Logged
If I understand what you're saying a similar thing happened to my 2way Rockford Fosgates. The speaker cone distorted and became "jammed" around the tweeter post. I was guessing it was do to overheating.
auex
Platinum - Posts: 5,041
Posted: August 29, 2004 at 8:43 PM / IP Logged
It was probably constructed using cheap materials and for some reason the cone physically distorted causing the cone to crack.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
jeffchilcott
Platinum - Posts: 2,483
Posted: August 29, 2004 at 9:16 PM / IP Logged
I think the only way the car jarring would have causeed this would be if the door was auctually flexing and bening the speaker, I really really hope this isnt your situation
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
goldfinger
Member - Posts: 38
Posted: August 29, 2004 at 9:59 PM / IP Logged
Interesting info guys.  I don't know much about speakers, but I'm pretty sure this isn't right.  Here's a picture, you can see the crack right down the middle.
clftn
Member - Posts: 9
Posted: August 29, 2004 at 10:04 PM / IP Logged
It does seem like it could be a defect. Maybe moisture and freezing weather(if it started to become damaged in january) then finally went on the dirt road. If you can, I say return them and stay away from the transparent series.
DYohn
Platinum - Posts: 10,741
Posted: August 29, 2004 at 10:07 PM / IP Logged
If it's still under warranty take it back for a replacement.
goldfinger
Member - Posts: 38
Posted: August 29, 2004 at 10:22 PM / IP Logged
Nah, I didn't have the problem until just a week or so ago *right* after going down the dirt road and it's been 95+ degrees here so it couldn't have been freezing.  I already ordered some replacement Blaupunkt's (not transparent) and I'm going to call them when I get time to see about warranty replacement.  They are stamped July 02, so they may not be under warranty.  I was aware they were closeouts when I bought them and the price reflected that.
Thanks for the info guys. :)
