port aiming
gcorrea
Silver - Posts: 436
Posted: August 30, 2004 at 12:13 AM / IP Logged
im building my sub box to kicker specs. but instead of firing my sloted ports through the front i would like to place them on the side of the box. problem is that i have about 5 to 6 inches of space between the box and the side of the cab. will this be to tight of an air gap for the port or should i just port them through the front. also what big difference does slot porting have over round porting. the port is 3"x12.5"x20.5"long.
gcorrea
jeffchilcott
Platinum - Posts: 2,483
Posted: August 30, 2004 at 6:09 PM / IP Logged
as a rule of thumb I try to keep my ports and subs on the same plane, and try to keep them from being blocked by any obstical.   If you have room do cented slot ports and fire up or forward in a truck, between the seats unless you have a bench then I would go up
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Monday, February 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
