Need Help deciding on new subs
Kick_ass2k1
Member - Posts: 6
Posted: August 30, 2004 at 10:32 PM / IP Logged
Hey guys. I currently have 2 kicker l7 12's runnign off a 2000 watt amp, and they hit hard. But I'm ready to play with the big dogs, and want more. I w3as thinking of adding 2 more subs to my setup, but i can't decide between 2 kicker cvr 18's or if 2 more l7 12's or 15's would be better. I'm looking for the most spl possible, probably playing the 2 12's regularly, and the 2 others only for comps. I have never heard an 18 in a car before, and so i was wondering if it was worth it (compared to a l7 15). Btw, these are going to be in a mustang hatchback :) Thanks a lot.
xtreamcc
Silver - Posts: 467
Posted: August 31, 2004 at 12:22 AM / IP Logged
personally I'd suggest getting 2 more 12's. The problem with mixing subwoofer sizes is that it takes some pretty good crossover skills and a good ear with the equalizer to keep from causing cancelation. The 2 18's and 2 12's would probably give you your best range of output but the 4 12's would prevent any size related cancilations. Anyway, my vote is for the 4 12's.
"Shiny chrome when used in conjunction with bikini models is particularly effective in inducing brain deficit disorder"
02 Jeep Grand Cherokee
Monster System on its way.
chevyman26
Copper - Posts: 227
Posted: August 31, 2004 at 12:32 AM / IP Logged
I would also go with the 4 12's. But if you are dead set on having different sizes, then the more difference in size the easier it will be to select and set crossovers to prevent any interference or cancellation problems.
You'd better get me out of this lord... or else you'll have me to deal with. -- Hunter S. Thompson "F.A.L.I.L.V."
Ravendarat
Platinum - Posts: 2,806
Posted: August 31, 2004 at 1:33 AM / IP Logged
I also say stick to the same sizes. If you want the most spl than sell off your 2 12's and buy 4 18's :) No replacement for displacment when it comes to spl
Tuesday, September 16, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
