door locks but wont unlock
tee17
Copper - Posts: 93
Posted: September 07, 2004 at 8:26 PM / IP Logged
i just installed a bulldog 62i remote start on my 92 lumina. everything is working fine. the only problme that i am having is that the doors will lock when i arm it but it wont unlock when i disarm. did i do somethig wrong or miss a step?
mo12v
Posted: September 07, 2004 at 9:00 PM / IP Logged
Are U sure U have 12 Volt + output to Unlock Wire?
1992 Lumina:  + pulse
Power LockLIGHT BLUEDRIVER KICK OR AT RELAYS
Power UnlockBLACKIN PASSENGER KICK PANEL
1992 Lumina APV:  + pulse
Power LockLIGHT BLUEEITHER KICK PANEL OR AT RELAYS
MO
tee17
Copper - Posts: 93
Posted: September 07, 2004 at 9:21 PM / IP Logged
i used the black wire that was at the drivers kick panel. am i suppose to use the one that is in the passenger kick panel?
mo12v
Posted: September 08, 2004 at 9:50 AM / IP Logged
NO.....
I usually run 2 wires over to Relays in passenger Kick panel, but U need to check (with meter, I hope) to see if U are getting 12 Volts + from your Unlock wire?? And Check the Car factory wire U hooked in to & see if that has 12 Volts + when U Manually Unlock your doors at the switch.
MO
Monday, May 20, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
