python 1500esp, a.k.a viper550esp?
tearjerky
Posted: September 09, 2004 at 10:14 PM / IP Logged
i know this question has been brought up in some threads but they just died without clarifications. i have an aftermarket alarm that has a remote start capability and an aux output for extra purposes. my question is , for 2k4 4runners, does it still need transponder bypass module ? what kind,how much and where to buy(no key required kind)? and with my present alarm with aux output, can it be programmed to have the rear window go down or do i just put the original remote with my keys just for that option? somebody mentioned an "ign?", is that something you ask from the dealer to get your aftrmrkt alarm system working with the rear window? please acknowledge. thanks!!!python 1500esp, a.k.a viper550esp? -- posted image.
auex
Platinum - Posts: 5,041
Posted: September 09, 2004 at 10:47 PM / IP Logged
Bypass involves "key in the box" type bypass and requires a spare key. All you have to do to get all the windows to work with the alarm is wire acc channels to the lock pulses.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
tearjerky
Posted: September 09, 2004 at 10:57 PM / IP Logged
wire acc channels to the lock pulses? can you expound please. thanks.
auex
Posted: September 09, 2004 at 11:00 PM / IP Logged
Ahh, big words hurting my head. Basically if you extend the amount of time the lock/unlock pulse sees the computer will roll all the windows up or down. So you wire additional outputs from the alarm to the lock wires. Then you push on the button to activate the channel, should be validity not latched, then after a couple of seconds the windows will start moving.
tearjerky
Posted: September 10, 2004 at 4:58 PM / IP Logged
thanks. would you happen to have a wiring diagram for toyota 4runner 2003-04? thanks
snguyen
Silver - Posts: 281
Posted: September 10, 2004 at 6:24 PM / IP Logged
{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}WIRING INFORMATION 2003 {/SPAN}{st1:City}{st1:place}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}Toyota{/SPAN}{/st1:place}{/st1:City}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"} 4Runner{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: white; FONT-FAMILY: Arial"}WIRE WIRE COLOR LOCATION{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}12V CONSTANT WHITE/ BLUE and RED Ignition Harness{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}12V IGNITION BLACK/ RED Ignition Harness{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}SECOND IGNITION BLUE / YELLOW Ignition Harness{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}ACCESSORY WHITE/ GREEN Ignition Harness{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}STARTER GREEN/ BLACK Ignition Harness{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}PARKING LIGHTS (+) GREEN In Plug On Left Side Of Fuse Box{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}POWER LOCK (-) BLUE Harness In Driver’s Kick Panel Or Harness{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}Coming From Driver’s Door{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}POWER UNLOCK (-){/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}GREEN Harness In Driver’s Kick Panel Or Harness{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}Coming From Driver’s Door{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}Test door locks while using the key in the driver door. Unlock requires a double pulse{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}DOOR TRIGGER (-) RED / BLACK (driver’s door){/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}PINK/BLACK (driver’s rear){/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}RED / YELLOW (front pass.){/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}PINK/BLUE (rear pass.){/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}Harness In Driver’s Kick Panel{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}Harness In Driver’s Kick Panel{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}Harness In Passenger Kick Panel{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}Harness In Passenger Kick Panel{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}HATCH TRIGGER LT.GREEN/ RED Driver’s Kick Panel{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}FACTORY ALARM ARM Arms with lock{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}FACTORY ALARM DISARM Disarms with unlock{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}FACTORY ALARM DISARM NO UNLOCK (-) GREEN/ YELLOW (key sense wire) Ignition Harness{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}TACHOMETER BLACK Test Connector In Diagnostic Plug By Under{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}Hood Fuse Box{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}BRAKE WIRE (+) GREEN/ YELLOW Back of Fuse Box{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}HORN TRIGGER (-) GREEN/ RED Steering Column{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}LEFT FRONT WINDOW UP LIGHT GREEN At Driver Window Motor Inside Door{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}LEFT FRONT WINDOW DOWN BLUE / YELLOW At Driver Window Motor Inside Door{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}RIGHT FRONT WINDOW UP RED / BLACK Harness In Driver’s Kick From Driver Door{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}RIGHT FRONT WINDOW DOWN RED / GREEN Harness In Driver’s Kick From Driver Door{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}LEFT REAR WINDOW UP RED / BLUE Harness In Driver’s Kick From Driver Door{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}LEFT REAR WINDOW DOWN RED / YELLOW Harness In Driver’s Kick From Driver Door{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}RIGHT REAR WINDOW UP YELLOW Harness In Driver’s Kick From Driver Door{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}RIGHT REAR WINDOW DOWN DARK GREEN Harness In Driver’s Kick From Driver Door{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}NOTE:{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: SymbolMT; mso-bidi-font-family: SymbolMT"}• {/SPAN}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}Some models are equipped with a factory Immobilizer system. This must by bypassed when installing a remote start system.{/SPAN}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial,Bold; mso-bidi-font-family: 'Arial,Bold'"}{/SPAN}{/p}
Please do not copy and paste from a rich text editor like Microsoft Word. Please copy and paste from a plain text editor like Notepad.
tearjerky
Posted: September 10, 2004 at 11:48 PM / IP Logged
{table width="100%" border="0" align="center" cellpadding="0" cellspacing="0"} {tr}{td class="bold"}snguyen wrote: {table width="100%" border="0" cellpadding="1" cellspacing="0" bgcolor="#cccccc"} {tr} {td}{table width="100%" border="0" cellpadding="2" cellspacing="0" bgcolor="#FFFFFF"} {tr} {td class="text" style="line-height:1.5em;"}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}{/SPAN}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial,Bold; mso-bidi-font-family: 'Arial,Bold'"}{/p}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}WIRING INFORMATION 2003 {/SPAN}{st1:City}{st1:place}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}Toyota{/SPAN}{/st1:place}{/st1:City}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"} 4Runner{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: white; FONT-FAMILY: Arial"}WIRE WIRE COLOR LOCATION{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}12V CONSTANT WHITE/ BLUE and RED Ignition Harness{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}12V IGNITION BLACK/ RED Ignition Harness{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}SECOND IGNITION BLUE / YELLOW Ignition Harness{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}ACCESSORY WHITE/ GREEN Ignition Harness{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}STARTER GREEN/ BLACK Ignition Harness{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}PARKING LIGHTS (+) GREEN In Plug On Left Side Of Fuse Box{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}POWER LOCK (-) BLUE Harness In Driver’s Kick Panel Or Harness{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}Coming From Driver’s Door{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}POWER UNLOCK (-){/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}GREEN Harness In Driver’s Kick Panel Or Harness{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}Coming From Driver’s Door{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}Test door locks while using the key in the driver door. Unlock requires a double pulse{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}DOOR TRIGGER (-) RED / BLACK (driver’s door){/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}PINK/BLACK (driver’s rear){/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}RED / YELLOW (front pass.){/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}PINK/BLUE (rear pass.){/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}Harness In Driver’s Kick Panel{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}Harness In Driver’s Kick Panel{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}Harness In Passenger Kick Panel{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}Harness In Passenger Kick Panel{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}HATCH TRIGGER LT.GREEN/ RED Driver’s Kick Panel{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}FACTORY ALARM ARM Arms with lock{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}FACTORY ALARM DISARM Disarms with unlock{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}FACTORY ALARM DISARM NO UNLOCK (-) GREEN/ YELLOW (key sense wire) Ignition Harness{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}TACHOMETER BLACK Test Connector In Diagnostic Plug By Under{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}Hood Fuse Box{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}BRAKE WIRE (+) GREEN/ YELLOW Back of Fuse Box{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}HORN TRIGGER (-) GREEN/ RED Steering Column{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}LEFT FRONT WINDOW UP LIGHT GREEN At Driver Window Motor Inside Door{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}LEFT FRONT WINDOW DOWN BLUE / YELLOW At Driver Window Motor Inside Door{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}RIGHT FRONT WINDOW UP RED / BLACK Harness In Driver’s Kick From Driver Door{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}RIGHT FRONT WINDOW DOWN RED / GREEN Harness In Driver’s Kick From Driver Door{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}LEFT REAR WINDOW UP RED / BLUE Harness In Driver’s Kick From Driver Door{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}LEFT REAR WINDOW DOWN RED / YELLOW Harness In Driver’s Kick From Driver Door{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}RIGHT REAR WINDOW UP YELLOW Harness In Driver’s Kick From Driver Door{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}RIGHT REAR WINDOW DOWN DARK GREEN Harness In Driver’s Kick From Driver Door{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}NOTE:{/SPAN}{/p}{P class=Msonormal style="MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: SymbolMT; mso-bidi-font-family: SymbolMT"}• {/SPAN}{SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"}Some models are equipped with a factory Immobilizer system. This must by bypassed when installing a remote start system.{/SPAN}{/td} {/tr} {/table}{/td} {/tr} {/table}{/td} {/tr} {/table} {/p}
auex
Posted: September 11, 2004 at 12:21 AM / IP Logged
QUIT USING WORD OR WORD PAD TO TYPE YOUR POSTS OR ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ HAPPENS!!!!!!!!!!!!!!!!!!
