Tach Signal - 2002 Mustang GT
kmhenry77
Member - Posts: 13
Posted: September 09, 2004 at 11:51 PM / IP Logged
Hello,
I need some help on how to get a Tach signal for the remote start on a 2002 Mustang GT.  I believe the engine has a coil on every spark plug rather than a traditional setup.  I am installing a Prestige APS996A on this auto.  Does anyone know what I need to do?
tbirdman74
Copper - Posts: 164
Posted: September 10, 2004 at 5:57 AM / IP Logged
 NOT red or WHITE/ lt. blue at coil pack
Tach Signal - 2002 Mustang GT -- posted image.
or
ORANGE / WHITE
PIN #48 AT POWERTRAIN CONTROL MODULE **
**Powertrain Control Module Located In Passenger Kick Panel
If it don't fit, Force it.
If it breaks, You needed a new one anyway!
kmhenry77
Member - Posts: 13
Posted: September 10, 2004 at 6:53 AM / IP Logged
My engine is different, it has no spark plug wires, just wiring that goes to 8 individual coils which sit on the end of the spark plug.
profuse007
Gold - Posts: 2,015
Posted: September 10, 2004 at 7:09 PM / IP Logged
*3 For the 3.8L motor, use the dk. blue/lt. green, RED / lt. blue, or the pink/white. All of these wires are found at the coil pack. The 4.6L motor uses a separate coil for each cylinder. Go to any coil and use the wire that is NOT red or WHITE/ lt. blue.
Houston,TX
xtremeaudio
Copper - Posts: 174
Posted: September 11, 2004 at 12:38 AM / IP Logged
use fuel injecter they are  the same at list they have 6 or 8 of them more easy to find
