02' Lexus IS300 fact. amp?
mxxmikexx
Silver - Posts: 796
Posted: September 14, 2004 at 7:44 PM / IP Logged
does the is 300 have a factory amp? if so, where is it located?
B19 O Dj
Posted: September 20, 2004 at 11:49 AM / IP Logged
Yes it does, in a UK IS200 it is located infront of the passenger door, tucked up behind the dashboard to the side. Its easy to spot, its silver, has a heatsink along one edge and 2 connectors on the forward edge.  I presume it will be the same on US IS300's.  The bad news is the sucker has no line level I/O that you can use to drive an aftermarket amplifier (The H/U and amp are closely integrated).  It is DIYable though, if you don't mind taking the case apart, you could do it in less than an hour.
raydawg357
Silver - Posts: 769
Posted: September 20, 2004 at 2:26 PM / IP Logged
If you drop the glove compartment, you can access it easily.
Do it right the first time
Tuesday, March 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
