91 camaro problem
estrda1
Posted: September 24, 2002 at 1:41 AM / IP Logged
I bought a Autopage RS-750LCD alarm and had it installed in my 1991 Chevy Camaro.The guy that installed in my car said that he wasnt able to activate the remote start feature and that I needed to buy another module to bypass something in the car,and also that I had to go to the dealer to get a spare key to put it in the module.Is this true?Does N E one know how much this bypass module cost?Thanks in advance.
aussie
Posted: September 24, 2002 at 4:50 AM / IP Logged
what he is talking about is the vats system you ignition key has a resistor built into it (the little black piece ) there is a 2 wire sleeved loom at the steering column measure the resistance value of your key and add a resistor of the same value between the wires this will let you operate a remote start
aussie-tech
Platinum - Posts: 12,488
Posted: September 24, 2002 at 7:00 AM / IP Logged
1991 Camaro does not have the VATS in it. Only the 1991 Corvette did from Chevy.
