remote start hookup problems
petesneeze
Member - Posts: 14
Posted: October 02, 2004 at 5:22 PM / IP Logged
Trying to hook up phoenix pd-175 remote starter on 97 Sebring Convertible
Car has pink/black - constant 12v
yellow- starter
ign 1 - blue
ign 2- GREEN/ red
ign 3 (heat/ac) -BLACK/ white
acc  (blower) - BLACK/ orange
pd-175 has 3 prewired relays with a blue, yellow, and 2 brown wires. The yellow is power for starter (i get that , yellow to yellow), The 2 brown come off the same relay and the diagram just says "key On". The diagram for the blue wire says "pwr supply wire for a/c or heat - ACC output". How do I connect these and do I need to add more relays?
THANKS MUCH !!!
pete
jrilla
Gold - Posts: 1,498
Posted: October 02, 2004 at 5:47 PM / IP Logged
The two brown wires are the outputs that power the vehicles Ignition wires. Your vehicle has 2 Ignition wires so you need to hook one brown to each. Blue goes to your acc wire.
I have 2 wire diagrams that both show a 97 Sebring Conv. to have the following wire colors:
12v: Pink/Black
Start: Yellow
Ign 1: Dark Blue
Ign 2: BLACK/ Orange
Acc: BLACK/ White
Since there is a discrepancy, just be sure to Test all the wires before making your connection.
J Rilla
Owner/Installer
petesneeze
Member - Posts: 14
Posted: October 04, 2004 at 11:26 AM / IP Logged
ok ..THANKS A LOT !!!
pete
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
