Resetting My ProStart CT-3300
Zilverado
Copper - Posts: 92
Posted: October 03, 2004 at 7:06 PM / IP Logged
Well, I do seem to have another problem with my ProStart CT-3300. I can?t reset it.
The instructions say to ?Flash? the hood pin and then step on the brake pedal 6 times within 10 seconds. The parklights should then flash 8 times to confirm reset. This is not working.
Can I reset the unit by just unplugging the wiring harness?
Zilverado,
Backyard Mechanic
1986 Chevy Truck & 1992 Nissan Pathfinder
Platinum - Posts: 12,488
Posted: October 03, 2004 at 9:03 PM / IP Logged
Try disconnecting the main harness. Aside from this, ProStart's are crap. I had the same problem with 3 units a couple of winter's ago and I had to get the customer's to return the CPU's to Canadian Tire.
Zilverado
Copper - Posts: 92
Posted: October 04, 2004 at 12:02 PM / IP Logged
Velocity Motors wrote:
...Aside from this, ProStart's are crap. I had the same problem with 3 units a couple of winter's ago and I had to get the customer's to return the CPU's to Canadian Tire.
Now you tell me.... ;-)
Zilverado,
Backyard Mechanic
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
