Mtx 801D wired to 1Ohm
Pola_Trucos
Member - Posts: 43
Posted: October 05, 2004 at 8:47 PM / IP Logged
Hi guys I just bought  a mtx 801D amp and it says that it is stable at 2ohm. I have two mmatts 4Ohm double coil subs and the guy from the local shop says that my amp is stable down to 1 ohm. He also told me that the amp will need a lot of juice so I bough a new svr battery reated at 1300 amps. So what do you guys say??????? I'm I good to go with the configuration or should I wait and buy two new subs? I just dont want to fry the amp. Thanks.
Dont use ten words when 5 will do fine.
furflier
Copper - Posts: 236
Posted: October 05, 2004 at 8:59 PM / IP Logged
I would not run this amp @ 1ohm . It will not be stable.2ohms is the lowest it is stable at. Either wire your subs in series/ parallel or get some new ones.
Platinum - Posts: 12,488
Posted: October 05, 2004 at 10:24 PM / IP Logged
I have yet to see an actual D-Class amp run stable at 1 ohm. Most don't  like performing optimumly( ?? think that's spelled correctly Mtx 801D wired to 1Ohm -- posted image. ) at 2 ohms, but they do. I think the shop is full of it and ask him if he will back his word that is this amp doesn't perform at 1 ohm, will he take it back.
Asmodeus
Silver - Posts: 393
Posted: October 05, 2004 at 10:48 PM / IP Logged
the only D class amp I can think of right off hand without looking is the Memphis MC1000D , The Memphis Belle MC1300D, and the Memphis "Baby Belle MC600D.....These 3 amps I know will run happily at 1 ohm...Just be ready to feed them, cuz they get hungry... [;)]
Making the World A Louder Place
jeffchilcott
Platinum - Posts: 2,483
Posted: October 05, 2004 at 11:35 PM / IP Logged
I havent had good luck with class d amps at 1 ohm unless they are pure breed comp amps...Normally I dont run anything at 1 ohm in a vehicle unless it is for comp or absolutly nessicary for heat and life reasons.   Dont get me wrong some amps preform very well for long times if reccomended at 1 ohm, but even some recomended at 1 ohm after a year of use will fail.    Unless it is a A/B amp I wouldnt go beyond the amps rating's...I own some older memphis products hc-100, hc-50 ect ect and they are recommended at no more then 1 ohm mono. I have been running mine for street beat at 1/2 ohm for quite a few months now and they preform great.   But I would not try it with a mtx d class
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Ravendarat
Platinum - Posts: 2,806
Posted: October 06, 2004 at 3:46 PM / IP Logged
MTX will not run at 1 ohm without ill effects. Plain and easy. The salesman is full of sh*t and should probally go sell insurance.
