Sunbird Remote Starter Manual
dan125
Posted: November 13, 2004 at 9:34 AM / IP Logged
does anybody knows how to install the things
dan125
Posted: November 13, 2004 at 9:36 AM / IP Logged
does anybody know the website for tis remote starter
spooge031
Member - Posts: 11
Posted: November 13, 2004 at 12:20 PM / IP Logged
try www.remostart.com BUT be aware these remotes are no longer made by thecompany and they may not provide any info any more
tuftrux
Member - Posts: 7
Posted: November 13, 2004 at 1:14 PM / IP Logged
Posted: October 19, 2004 at 9:38 PM - IP Logged Sunbird Remote Starter Manual - Page 2 -- posted image.
I contacted the company,they said they don't carry that model and cannot help-going to have to find someone that has them figured out or has the manual.The market is flooded with these things for sale,all w/out manuals......
___________________________________________
Joe
PS It seems to me that a little logic and some bench testing could solve this mystery.Generally your red and black are your 12v + and -,yellow is generally the ignition,the others are giong to be ignition 1,2,and possibly 3.Do a little experimenting on the bench,should be able to figure it out.Wire in your black and red,check the other functions by using the remote and a meter.......
Joe
madtechie
Posted: November 14, 2004 at 5:22 PM / IP Logged
Hello all!!  I am a new member to the12volt.com, and I am happy to come bearing gifts!  LOL   I have information on the Sunbird DG-003 remote starter that so many of us have unwittingly purchased without directions or even a way to contact the manufacturer.  Lead routing is as follows:
main harness-
Solid Black--Chassis ground
Solid Red-- Battery (+12v constant)
Solid Blue-- Ignition #1 (Engine ECU, fuel pump, coil)
Blue/White Stripe-- Ignition #2
Solid Green-- Accessory
Solid Yellow-- Start #1 (Starter solenoid)
RED / Yellow Stripe-- Start #2
20 ga. black--antenna
Hope this helps......... and good luck.  The plug will most likely have to be cut off, unless you can find a male end at Radio Shack or another electronics store...personally I intend to simply hard wire the system into my van.
                                            Good luck,    Christopher
tuftrux
Member - Posts: 7
Posted: November 14, 2004 at 8:25 PM / IP Logged
 Ata Boy Christopher!!!!  About time this was put to rest.Viva la Christopher! Do you have actual documents for these things.or did you figure it out the hard way?
Joe
madtechie
Posted: November 15, 2004 at 7:02 AM / IP Logged
Joe,
I dismantled the brain, and the connects were actually labeled on the printed board.  Being a skeptic by nature, I got out the meter, power supply, and light bulbs and tested the connects for accuracy, and presto!
~Christopher
mrbfh
Posted: November 15, 2004 at 8:35 AM / IP Logged
Thanks, Christopher. Doing the test meter/light bulb thing was something I intended to to "when I have time", so I'm glad you did it. You have helped many people. Thanks again!
dan125
Posted: November 16, 2004 at 10:12 AM / IP Logged
Solid Green-- AccessorySolid Blue-- Ignition #1 (Engine ECU, fuel pump, coil)
RED / Yellow Stripe-- Start #2system into my van.
              WHERE DO I FIND THESE WIRS IN MY FORD WINDSTAR
kudjo
Posted: November 19, 2004 at 7:08 PM / IP Logged
Remostart.com never made the sunbird DG-003 remote starter as suggested, hence their database doesn't carry the installation manual for this remote starter.
Page of 4
