2001 cavailer horn honk
bear80
Member - Posts: 21
Posted: October 15, 2004 at 3:25 PM / IP Logged
i have a 2001 cavailer i would like to make the horn hunk  the wire they say to go to has 12 volts on it how can get this to work
SoundFX411
Copper - Posts: 153
Posted: October 15, 2004 at 3:31 PM / IP Logged
Supply the Black wire at the steering column with a negitive trigger. If your alarm has a + siren trigger then you will need a relay to switch polarity.
bear80
Member - Posts: 21
Posted: October 15, 2004 at 3:34 PM / IP Logged
the alarm has a negitive so this will work just hook it  wright to the black  wire that has 12 volts
sparkie
Platinum - Posts: 2,061
Posted: October 15, 2004 at 4:10 PM / IP Logged
Unless the negative output of which you speak is designed for horn honk, DON'T use it. If it is for a siren, the out put will be constant not pulsed like you need. A constant horn honk will burn out the horn in short time, not to mention be very annoying. Sirens have their pulse feature built into them. You would have to use a relay and flasher circuit to pulse the horn.
sparky
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
