01' nissan altima trunk release
mpathy
Member - Posts: 47
Posted: October 18, 2004 at 5:15 PM / IP Logged
  Is there a way to get thr trunk on a 01' altima to pop thru aftermarket remote . I am installing a DTI alarm/rs and want to connect my trunk.
  I can pop my trunk thru my factory but I have a a manual lever as well.
 Any help is great .....
Thank you in advance
Sexified
Copper - Posts: 87
Posted: October 18, 2004 at 5:33 PM / IP Logged
so long as you have the (-)from the bcm. usually it is the RED / black and if the switch is on the drivers door you will need to run your own wires into the door. you can get the factory alarm to arm/disarm,re-arm,as well as lock,and un-lock the doors,as long as you go directly to the factory window and lock switches. if you use a long enough pulse on the lock wire you can also automatically have the windows roll up and vice/versa on the un-lock.
mpathy
Member - Posts: 47
Posted: October 18, 2004 at 5:58 PM / IP Logged
Thanks for that info . My issue is that I have a lift lever for my trunk release. I am thingkinh that there may be a motor ony to pop the trunk with the remote. I am not sure .. Hvae you seen this before?
mo12v
Posted: October 18, 2004 at 5:59 PM / IP Logged
This is what I have:
Trunk ReleaseORANGE / BLACK (-)AT "SMART ENTRANCE CONTROL UNIT" *
* "Smart Entrance Control Timer" Is A BLUE Module Located Behind The Driver Dash To The Right Of The Steering Column.
MO
mpathy
Member - Posts: 47
Posted: October 18, 2004 at 6:00 PM / IP Logged
   Thanks for that info ..
   My thing is that I have a lift lever for my trunk release inside. I don't have a button on the door.. Have you seen before? What do I do ?
mo12v
Posted: October 18, 2004 at 6:11 PM / IP Logged
OOPS..............WRONG info
If U have JUST a Levr & no Electric solinoid / motor in trunk U may S.O. L.
There R Universal Trunk Releases available, but it may be fun to install
MO
mo12v
If U have JUST a Lever & no Electric solinoid / motor in trunk U may S.O. L.
MO
mpathy
Member - Posts: 47
Posted: October 18, 2004 at 6:16 PM / IP Logged
Sorry for the double post....
  Thanks all for the help.
Sexified
Copper - Posts: 87
Posted: October 19, 2004 at 7:44 AM / IP Logged
have to tried going directly to the trunk motor? you might be able to do 5 wire trunk release, but make sure when you try that, you use a fuse holder, if it's not 5 wire it may feedback to the module......(may be an expensive fix)otherwise just install a trunk release solonoid.
