Prestige APS-992A, 2000 Dodge Durango
murphy286
Member - Posts: 11
Posted: October 26, 2004 at 4:17 PM / IP Logged
     Should I install my alarm myself.  I was looking at the Prestige APS-992A.
Just a little bit of history about myself before you make your decision.  I worked for National Guardian systems for 4 years (bought out my Ameritech) installing burglary alarms, fire alarms, CCD camera, card access systems, and gate entry.  I even had to build a custom alarm panel from resistors and relays so it would do what a customer wanted it to do.  I know a little about circuitry.  I have looked at professional installed car alarm systems, and they really don't look at much differenat than home alarm systems.  Basicly the brain reads a certain resistance value, and if that value changes it sets the alarm; through open circuits or dead shorts.  The outputs on the alarm are basicly form c relays?? correct??  You wire up the wire from the starter through a normally closed side of the relay.  when the alarm goes off, it opens the relay????  Let me know if I'm close.  Thanks for your input.
Platinum - Posts: 12,488
Posted: October 26, 2004 at 6:56 PM / IP Logged
With the knowledge that you have I'm sure you can install a basic alarm system with the proper wiring datasheet for the vehicle and some assistance here. The alarm systems are easy to do, it's the remote starts that you have to worry about now a days. Post questions if you have any more about your installation.
Just curious, what make, mode and year vehicle is this alarm going into ?
accordcoupe94
Member - Posts: 29
Posted: October 26, 2004 at 11:37 PM / IP Logged
i am sure that you can do it wiithout any problems. i do not know half of what you are talking about in your post and i managed to install a viper 791xv in my honda accord in 4 hours on my first try. i am more of a hands on type of person and i learn by looking at things rather than reading and studying about them. since you already have that aspect covered, i am sure you will be just fine. personally, if you can see colors and strip a wire, i think you can install an alarm.
thepencil
Gold - Posts: 1,526
Posted: October 27, 2004 at 9:14 AM / IP Logged
With that kind of knowledge and experience that you have I know you will do just fine. Just post your questions here if you run into trouble. I am sure there are enough people here who can help you out.
Be careful whose advice you buy, but be patient with those who supply it.Prestige APS-992A, 2000 Dodge Durango -- posted image.
murphy286
Member - Posts: 11
Posted: October 29, 2004 at 12:49 PM / IP Logged
Thanks to everyone who replied.
Velocity Motors,
      I am installing the alarm in a 2000 Dodge Durango.  The vehicle only has a remote lock/unlock with panic to the horn.  I don't have to use the remote to open the doors.  I don't think I have to worry about that at all.??.???
snguyen
Silver - Posts: 281
Posted: October 29, 2004 at 4:44 PM / IP Logged
ItemWire ColorPolarityWire Location
12Vred or pink/black+ignition harness
STARTERyellow+ignition harness
IGNITIONdk. blue+ignition harness
ACCESSORYBLACK/ orange+ignition harness
SECOND ACCESSORYGREEN/ red+ignition harness
TACHOMETERBLACK/ grayignition coil
POWER LOCKlt GREEN/ orange*3*1
POWER UNLOCKsame wire*3
PARKING LIGHTS +BLACK / YELLOW*1
PARKING LIGHTS -none
DOOR TRIGGERblk/blu & tan/red *2-*1
HEADLIGHTSlt. green-steering column
WIPERS*4+steering column
LF WINDOW UP/DNlt. blue - whiteCat drivers door switch
RF WINDOW UP/DNbrn/wht - brn/whtCat drivers door switch
LR WINDOW UP/DNblu/wht - RED / blkCat drivers door switch
RR WINDOW UP/DNgry/blk - grn/whtCat drivers door switch
TRUNK/HATCH PINtan/black-*1
HOOD PINnone
TRUNK/HATCH RELEASEnone
FACTORY ALARM ARMarms with lock*1
FACTORY ALARM DISARMdisarms with unlock*1
HORN TRIGGERBLACK/ red-steering column
BRAKE WIREWHITE/ tan+at brake pedal switch
LOCK MOTORORANGE / blackdrivers kick panel
UNLOCK MOTORbluedrivers kick panel
DISARM DEFEATpink/blackdrivers kick panel
DISARM NO UNLOCK*3
DOME SUPERVISIONnonenonnone
SPEED SENSEnonenonnone
SUN ROOF OPEN/CLOSEnonenonnone
SUN ROOF LIMITnonenonnone
LF SPEAKERnonenonnone
RF SPEAKERnonenonnone
LR SPEAKERnonenonnone
RR SPEAKERnonenonnone
RADIO 12Vnonenonnone
RADIO GROUNDnonenonnone
RADIO SWITCHnonenonnone
RADIO ILLUMINATEnonenonnone
POWER ANTENNAnonenonnone
Notes:*1 Located at a black plug in the drivers kick panel, to the right of the parking brake. *2 The BLACK/ blue catches the drivers door and the tan/red catches all other doors. Use both wires and diode isolate each. *3 Must use relays and set up for (-) negative trigger. Place a 647 ohm resistor to the lt. GREEN/ orange for arm/lock, and a 1562 ohm resistor on the same wire for disarm/unlock. Unlock requires a double pulse. *4 Use GREEN/ red for intermittent, purple for low, and RED / gray high.
snguyen
Silver - Posts: 281
Posted: October 29, 2004 at 4:45 PM / IP Logged
 DURANGO 2000-2003
WIRE COLORSLOCATION
12 VOLTS CONSTANTPINK/BLACK or REDIGNITION SWITCH HARNESS
IGNITION 1DK. BLUE (+)IGNITION SWITCH HARNESS
IGNITION 2RED / WHITE (+)IGNITION SWITCH HARNESS
IGNITION 3GREEN (HEAVY)  (+)IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER BLACK/ ORANGE (+)IGNITION SWITCH HARNESS
STARTERYELLOW (+) IGNITION SWITCH HARNESS
PARKING LIGHTSBLACK / YELLOW (+)@ LIGHT SWITCH HARNESS
DOME LIGHTYELLOW (-)@ HEADLIGHT SWITCH
DOOR TRIGGERSSee NOTE ****
POWER DOOR LOCKWHITE/ GREEN See NOTE *@ CTM, Connector #2 Pin 10 See NOTE **
POWER  DOOR UNLOCKWHITE/ GREEN See NOTE * @ CTM, Connector #2 Pin 10 See NOTE **            *SEE DIAGRAM*
TACH SENSORSee NOTE ***
BRAKEWHITE/ TAN (+)@ THE SWITCH ABOVE THE BRAKE PEDAL
HORNBLACK/ RED (-)@ STEERING COLUMN HARNESS
FACTORY DISARMDISARMS with UNLOCK
FACTORY ANTI-THEFTCHRYSLERS SENTRY KEYTRANSPONDER (grey keys only)
snguyen
Silver - Posts: 281
Posted: October 29, 2004 at 4:46 PM / IP Logged
Dodge
Durango
2000-2002
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
YELLOW
Ignition  #1:
DK. BLUE
Ignition #2:
GREEN/ RED
Ignition  #3:
N/A
Accessory:
BLACK/ /ORANGE & GREEN (2 WIRES)
IGNITION SWITCH HARNESS (BLOWER MOTOR)
Brake  Light:
WHITE/ TAN
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
BLACK/ GRAY
AT IGNITION COIL OR AT PCM *
Parking Lights:
BLACK / YELLOW
AT HEADLIGHT SWITCH
Headlights:
LT. GREEN
AT HEADLIGHT SWITCH
OEM Alarm  Disarm:
LT. GREEN/ ORANGE (-)
# PIN CONN. BELOW DR. FUSE BLOCK
OEM Alarm  Arm:
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * Ignition Coil Is Located On Passenger Front Of Engine. Powertrain Control Module (PCM) Is Located On Passenger Rear Of Engine Compartment In Front Of Washer Fluid Reservior.
Dodge
Durango
2000-2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED & PINK/BLACK
Starter  Kill:
YELLOW
Ignition  +12 Volts:
DK. BLUE
Dome  Lights/Superv:
YELLOW (-)
AT COURTESY LIGHT UNDER DASH
OEM Horn:
BLACK/ RED (-)
Power  Lock:
GREEN / WHITE
AT CENTRAL TIMER MODULE IN DRIVER'S KICK PANEL ***
Power  Unlock:
GREEN / WHITE
Trunk  Release:
N/A
Alarm  Input Wire:
YELLOW (-)
Notes:
*** See Installation Note #211. Single Wire Lock System, A Negative Trigger Through A 820 Ohm Resistor Will Lock Doors. A Negative Trigger Through A 330 Ohm Resistor Will Unlock Doors. **** Single Wire System, A Negative Trigger Through A 644 Ohm Resistor Will Arm And Lock The Doors. A Negative Trigger Through A 1565 Ohm Resistor Will Disarm The Alarm And A Second Pulse (Double) Will Unlock The Doors.
murphy286
Member - Posts: 11
Posted: November 02, 2004 at 6:58 AM / IP Logged
snguyen,
     Thanks for the wiring diagrams.  They will help.  I hope you don't mind if I PM you if I have any further questions about the 2000 durango.
     If anyone else has a 2000 (or similar) model durango I would like to know.  Thanks guys, you all have been a great help.
