1996 Ford Ranger Door Locks
doc t
Copper - Posts: 169
Posted: November 01, 2004 at 8:46 AM / IP Logged
Roger that will ground to the body, being that i live in j-ville ,fl and heater is a non issue, won't worry about it (he can suffer with out a/c and save some gas) it will build character! I will find out the color and function of the other wires that i had questions about later today when my son gets out of school and will post my questions, thank you for all your help.
draasch
Gold - Posts: 2,172
Posted: November 01, 2004 at 8:50 AM / IP Logged
hey doc, i am located in tampa and i have the same unit in both of my cars.......let me know if you need anymore help..
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
doc t
Copper - Posts: 169
Posted: November 01, 2004 at 9:46 AM / IP Logged
would you mind e-mail or just use the forum?
draasch
Gold - Posts: 2,172
Posted: November 01, 2004 at 10:15 AM / IP Logged
doesnt matter to me, i will get the email faster...its up to you...
Good Luck
David
Ace Security
813-376-9778
Tampa
doc t
Copper - Posts: 169
Posted: November 01, 2004 at 11:21 AM / IP Logged
Just got off the phone with him and here they are…
Yellow/red:   Factory arm output
Grey: 2nd ch or (-) trunk output
White: (-) arm input
Brown: (-) disarm input
Pink/black: remote start external activation
I told him to ground the blue/white neutral safety wire to the body.
Not sure about the above mentioned on if they are needed or not that is why I didn’t hook them up
The truck had a keyless entry but no alarm.
Thank you in advance for your support.
doc t
Copper - Posts: 169
Posted: November 01, 2004 at 11:24 AM / IP Logged
doc t
Copper - Posts: 169
Posted: November 01, 2004 at 11:26 AM / IP Logged
guess you can't cut & paste
i e-mailed it to you
doc t
Copper - Posts: 169
Posted: November 01, 2004 at 11:44 AM / IP Logged
did not connect:
yellow/red: factory arm output
gery: 2nd ch or (-) tunrk output
white: (-) arm input input
brown: (-) disarm input
pink/black: rem start external activation
the truck keyless entry on alarm, and the wire location was not given in the discription/location in the previous post.
Thanks for your support
doc t
Copper - Posts: 169
Posted: November 01, 2004 at 11:45 AM / IP Logged
did not connect:
the truck had keyless entry no alarm, and the wire location was not given in the discription/location in the previous post.
doc t
Copper - Posts: 169
did not connect:
grey: 2nd ch or (-) trunk output
Page of 3
