Power Wire Question
jonbth
Member - Posts: 42
Posted: November 01, 2004 at 10:40 PM / IP Logged
I'm going to install a Valet 561t remote starter on my Nissan Frontier. The module has 2 12v inputs and I'll need at least 1 and maybe 2 relays. Can I draw all my power from the 12v ignition switch wire? I think that wire is 40amp fused from the battery.
Ben.c
Member - Posts: 29
Posted: November 01, 2004 at 10:46 PM / IP Logged
You can hook up many relays to the main power supply feeding the ignition switch ( constant 12v+) . The remote start sytems wont draw any more power than your vehicle being started by the the key . Some remote start systems such as DEI use a lot of relays , I have hooked up as many a 10 relays on a sytems with many features with no problem.
ozy installer
snguyen
Silver - Posts: 281
Posted: November 02, 2004 at 8:29 AM / IP Logged
Make sure you fuse each connection.
