791XV Domeslight Supervision
jmr964
Copper - Posts: 70
Posted: November 02, 2004 at 9:55 AM / IP Logged
Can someone with a 791XV test their domelight supervision and report back to me.  What I want to know is that if after the vehicle has been remote started while the system is armed and you disarm the alarm while it is running under remote start is does the 791XV domelight supervision circuit kick on the domelights?  Mine doesn't and I think it should.
Jason
raydawg357
Silver - Posts: 769
Posted: November 02, 2004 at 10:36 AM / IP Logged
It works anytime the it's armed and disarmed, it doesn't matter if the the vehicle is remote started or not.
Do it right the first time
jmr964
Copper - Posts: 70
Posted: November 02, 2004 at 10:38 AM / IP Logged
Are you just saying this or have u verified that with a functinal 791VX?
Jason
raydawg357
Silver - Posts: 769
Posted: November 02, 2004 at 10:54 AM / IP Logged
I install them on a daily basis.  The 791 has seperate outputs that will allow you to connect other lights (such as neon) to the remote start option, but the dome light supervision is just that... dome light supervision.  When connected to your door trigger, it has no other function.
jmr964
Copper - Posts: 70
Posted: November 02, 2004 at 11:05 AM / IP Logged
I understand that but what I am experiencing is that the domelight supervision wire supplies the ground output fine if the vehicle is not remote started but if it is remote started it does not supply the domelight supervision ground if u unlock the doors/disarm the alarm.
Jason
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
