i need help to command start pls
LaB^KiTa
Posted: November 02, 2004 at 10:14 AM / IP Logged
i dont know if im stupid but i dont have enought money to buy the manual trans command starter my friend give me automatic command start but my car is manual i install the command start and its working i bypass the starter so i dont have to step on the cluch to start but there is no safety for it can u guys help me tomake it safety so if the car is on gear the car wont start can i use relay for it? pls help ty
LaB^KiTa
neener
Member - Posts: 27
Posted: November 02, 2004 at 11:09 AM / IP Logged
You can use the reverse lights as one step to make sure that it is not in that gear, but I don't know of a trigger that will tell you that your car is in gear. You could use some type of switch mounted to the shifter that shows it is in nuetral.
hurtado_roberto
Copper - Posts: 196
Posted: November 02, 2004 at 11:24 AM / IP Logged
They sell manual trand command starters?  For all I know you can only safely use a remote start system on an automatic car.  On the viper autostarters they always state that it's for automatic cars.
I've been thinking of a way but have not found it yet.  I noticed that the ford focus tells you what gear you're in.  On that car you could probably look for a wire to tap into using a relay.  When it's in neutral it would close the circut allowing it to start the car. but this signal is probably not present when the car is off.
you could put little pin switches on each gear at the stick shifter so that if any of them is close it will not allow the car to turn on but this could be difficult to do.
Poly Dollies
Member - Posts: 45
Posted: November 09, 2004 at 2:55 PM / IP Logged
If you don't know, now you know...ultrastart 1250m is a manual transmission remote starter. it interfaces with the parking brake and door triggers to give a fail safe remote start w/o poss of it starting in gear...here's how it works. the unit is always in safe mode until the time you are ready to use it and to put it in start mode, when you stop and put park brake on, you hit foot brake. when unit sees these two inputs together, it will chirp. then you exit the vehicle like you normally would, but when you take the keys out, it will stay running until you are out and the last door closes. obviously, for you to exit the vehicle while it is running, it HAS to be in neutral or it would jump and stall. the unit will remote start now unless a door is opened, then you have to put it back in start mode. the only difference between setting the mode and getting out of your car like you normally would is you have to tap the footbrake before taking the keys out. I install these all the time and they work perfectly. I actually installed an automatic unit on a manual once and the guy said,"oh, I never leave it in gear...ever!" and guess who's truck took off across the street in reverse and took out the neighbor's central air conditioning system... don't be fool, use your tools....
I tell it like it is...
