Dome light Question
flord
Member - Posts: 10
Posted: November 06, 2004 at 10:17 PM / IP Logged
I have a 2001 F-250 Superduty with factory keyless entry. The previous owner had a Ultra Start U-1500 installed, no dome light supervision (older model). I would like to trigger the factory dome light supervision (stays on for about 30 sec) with the ultra start fob. I think I have read that you can run a diode off the negative door trigger back to a module? A pulse relay timer is also another possability but I wanted to check it out with everyone here.
Jim
Thanks Jim
daniel2002p
Silver - Posts: 524
Posted: November 07, 2004 at 9:59 AM / IP Logged
Honestly, not sure if that is possible, you would have to get a timed relay for that.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
flord
Member - Posts: 10
Posted: November 07, 2004 at 11:31 AM / IP Logged
Thanks, daniel2002p.
 Anyone sitting back with a sunday coffee and an idea please jump in. It sure is hard typing wiyh a two year old jumping all over you.
Thanks Jim
hagmanti
Silver - Posts: 304
Posted: November 08, 2004 at 1:37 AM / IP Logged
Have you looked at:
https://www.the12volt.com/relays/page4.asp
Look at the diagram for negative door triggers. If your alarm has an output, hook that up where the diagram says negative door trigger. If it doesn't, use the lock wire of your alarm (I think I remember that your car has negative lock wires), appropriate diode-isolated...
Me
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
