Posted: November 09, 2004 at 2:39 PM / IP Logged
Posted: November 09, 2004 at 3:51 PM / IP Logged
Posted: November 09, 2004 at 5:59 PM / IP Logged
Posted: November 09, 2004 at 6:21 PM / IP Logged
Posted: November 09, 2004 at 6:33 PM / IP Logged
Posted: November 09, 2004 at 6:36 PM / IP Logged
Posted: November 09, 2004 at 6:42 PM / IP Logged
Posted: November 09, 2004 at 7:03 PM / IP Logged
Posted: November 09, 2004 at 7:12 PM / IP Logged
Posted: November 09, 2004 at 7:14 PM / IP Logged
Tuesday, January 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
So I think I'm going to patch into the wiring harness for my multifunction headlight switch and wire up my own relay. I wanted to make sure that by connecting the relays coil between the battery and the lo-beam switch on my multifunction cluster, the small wires and the relay coil wouldnt just go up in smoke from all that current from the battery. The battery would also connect to the switched side of the relay and directly to the lo-beam connector on my headlights. So I'm really bypassing the car's electrics for the lo-beams with my own. So if I'm understanding correctly, a relay coil rated at 12v and 600mA will be fine just hooked right up to the battery? What about ohm's law? It would seem that you would need a resistance of 20 ohms with that, given r=v/i. Do you understand where I'm confused here? Say I had a device that required 12v and no more than 60mA. Would I need a resistor for that?
Thanks alot for the help Teken!
. I tried EVERYTHING, minus tearing apart the wiring harnesses. I replaced the whole multifunction cluster. I replaced both headlight bulbs. I checked all the fuses and relays. So its safe to say it's either a broken or severed wire, or a bad ground. And I'm not ready to tear the car apart looking for that exact spot. So I believe this is the last option. Plz check the other thread someone posted about LEDs and resistors, I think I finally passed my mental roadblock.
