2001 Mustang Wiring
cericthered
Member - Posts: 15
Posted: October 07, 2002 at 7:18 PM / IP Logged
Does anyone have a wiring diagram, or wiring information  for a 2001 Mustang  3.8 L  ?
I am installing a Viper 550esp Alarm/Remote Start and I really need some information on this car before I can do this!  Thanks for any help,
Eric
Platinum - Posts: 12,488
Posted: October 07, 2002 at 7:22 PM / IP Logged
|              12V|yellow & lt. grn/pur|+  |ignition harness            |
|          STARTER|WHITE/ pink          |+  |ignition harness            |
|         IGNITION|RED / lt. green       |+  |ignition harness            |
|  SECOND IGNITION|gray / YELLOW         |+  |ignition harness            |
|        ACCESSORY|BLACK/ lt. green     |+  |ignition harness            |
| SECOND ACCESSORY|RED / black           |+  |ignition harness            |
|       POWER LOCK|lt. green           |+  |low in drivers kick or *1   |
|     POWER UNLOCK|purple              |+  |low in drivers kick or *1   |
|       LOCK MOTOR|RED / white           |   |low in drivers kick or *1   |
|     UNLOCK MOTOR|RED / orange          |   |low in drivers kick or *1   |
|    DISARM DEFEAT|pink/orange         |   |GEM module *1               |
| PARKING LIGHTS +|brown               |   |light switch or drivers kick|
| PARKING LIGHTS -|WHITE/ black         |   |*1                          |
|       HEADLIGHTS|RED / yellow          |+  |light switch                |
|     DOOR TRIGGER|*2                  |-  |*2                          |
| DOME SUPERVISION|BLACK/ white         |+  |drivers kick panel or *1    |
|  TRUNK/HATCH PIN|BROWN / white         |-  |drivers kick panel or *1    |
|TRNK/HTCH RELEASE|purple / YELLOW       |+  |drivers kick panel          |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|dk. GREEN/ purple    |-  |drivers kick panel or *1    |
| DISARM NO UNLOCK|                    |   |                            |
|       TACHOMETER|*3                  |   |*3                          |
|      SPEED SENSE|WHITE/ orange        |   |PCM pin 68 *4               |
|       BRAKE WIRE|RED / lt. green       |+  |brake switch                |
|     HORN TRIGGER|yellow/lt. green    |-  |steering column or *1       |
|           WIPERS|white & dk. blu/orn |+  |wiper motor                 |
|  LF WINDOW UP/DN|wht/blk - wht/blk   |A  |drivers window motor        |
|  RF WINDOW UP/DN|tan/blu - wht/yel   |A  |drivers kick panel          |
|  LR WINDOW UP/DN|yel/blu - gry/orn   |A  |drivers kick panel          |
|  RR WINDOW UP/DN|yel/blk - RED / blk   |A  |drivers kick panel          |
|        RADIO 12V|lt. GREEN/ violet    |   |at the radio                |
|     RADIO GROUND|black               |   |at the radio                |
|     RADIO SWITCH|BLACK/ pink          |   |at the radio                |
| RADIO ILLUMINATE|lt. blue/red        |+  |at the radio                |
|    POWER ANTENNA|ORANGE / lt. blue     |+  |at the radio                |
|       LF SPEAKER|orn/grn - blu/wht   |   |at speaker or amplifier *5  |
|       RF SPEAKER|wht/grn - grn/orn   |   |at speaker or amplifier *5  |
|       LR SPEAKER|gry/blu - tan/yel   |   |at speaker or amplifier *5  |
|       RR SPEAKER|orn/red - brn/pnk   |   |at speaker or amplifier *5  |
Notes:
NOTE:  This vehicle has the PATS anti-theft system.    *1 Also found at the GEM module located above the drivers kick panel to the drivers side of the steering column.  *2 There are two door trigger wires.  Use yellow/black for the drivers door and gray/red for the passengers door. Both wires are found above the drivers kick panel in a 20 pin connector. Use both wires and diode isoate each.   *3 For the 3.8L motor, use the dk. blue/lt. green, RED / lt. blue, or the pink/white.  All of these wires are found at the coil pack.  The 4.6L motor uses a separate coil for each cylinder.  Go to any coil and use the wire that is NOT red or WHITE/ lt. blue.   *4 The PCM is located behind the passenger kick panel.   *5 The amplifier is located just below the radio.
