Keyless Entry Relays
stealth_32
Posted: November 10, 2004 at 2:34 PM / IP Logged
Hello, I am working on a '32 ford with shaved door handles and I want to install a keyless entry system so I can open the door with a touch of a button.  Does anyone have any ideas on how I can achieve this.  I only need to open one door and the trunk.  I am thinking that I can use a keyless entry but instead of un-locking the doors it will fire the actuator for the door.  Thanks for any input!!!!!!!
auex
Platinum - Posts: 5,041
Posted: November 10, 2004 at 10:59 PM / IP Logged
All you have to do is wire the unlock to this relay diagram, - trigger is going to be the unlock output and +12V output will go to the solenoid.
Keyless Entry Relays -- posted image.
Same principal for the trunk but using an accessory output from the alarm.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
stealth_32
Posted: November 12, 2004 at 6:40 AM / IP Logged
Thanks auex!  I was thinking it woould be that way, but now you helped confirm it.  THANKS!
