Buzzer sounding from parking lights
kuhurdler
Member - Posts: 6
Posted: November 15, 2004 at 7:50 AM / IP Logged
1995 Chevy S-10 Ext-Cab
DEI Viper 600 esp
I have hooked up my alarm's light-flash-output to the parking lights wire as instructed. Brown wire I think.
Every time my lights flash, my buzzer sounds (since the key is not in the ignition). Is this normal? Is there a way to prevent it besides removing the buzzer?
Sexified
Copper - Posts: 87
Posted: November 15, 2004 at 7:56 AM / IP Logged
try it with the door closed, you may have the wrong wire....go to the light switch itself and test it with a test light or a multimeter.
sweet.
ampere
Member - Posts: 40
Posted: November 15, 2004 at 8:02 AM / IP Logged
Or you could just use your Hazard lights instead.
kuhurdler
Member - Posts: 6
Posted: November 15, 2004 at 9:55 AM / IP Logged
Thanks for the replies.
Door open/closed makes no difference.  I literally tapped onto the wire right behind the light switch.  The truck thinks I left my parking lights on when the truck is not running, so it buzzes.  For locked it flashes the lights once (short buzz).  For unlocked it flashes the lights twice (buzz buzz)
Its something I could live with, I just figured there may be an easy solution I'm not thinking of.  Is it typical for alarms to behave that way?
Where is a good place to tap onto the hazard lights?  Will it flash the same or will the hazard-delay mess up the flash?
sparkie
Platinum - Posts: 2,061
Posted: November 15, 2004 at 4:32 PM / IP Logged
The condition is normal and won't cause any harm. Leave your system hooked up to the brown wire.
sparky
dragonrage
Copper - Posts: 193
Posted: November 18, 2004 at 3:25 AM / IP Logged
You could put the buzzer on a relay so that the buzzer is normally connected, but disconnects when the alarm triggers the lights.
2009 Pontiac G8 in planning stage
HU: ?
Speakers: ?
Amps: ?
Wednesday, November 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
