Half my speakers quit???
fj40john
Member - Posts: 17
Posted: November 17, 2004 at 1:04 PM / IP Logged
After installing a cheap amp and a pair of 10's, the left side speakers in my truck don't work at all. I did screw up and shoot some sparks out of the amp's power wire (grounded with screwdriver), and it blew the power wire fuse, but I replaced the fuse and that whole setup works. Is the reciever the problem here?
fj40john
Member - Posts: 17
Posted: November 17, 2004 at 1:07 PM / IP Logged
Forgot to add, this is a '99 F-250 Superduty Crew Cab, stock head unit, and speakers.
speedwayaudio1
Silver - Posts: 879
Posted: November 17, 2004 at 1:08 PM / IP Logged
I think the amps done. try another amp, and be careful this time. See if everthing works. good luck.
Big Dave
DYohn
Moderator - Posts: 10,741
Posted: November 17, 2004 at 1:10 PM / IP Logged
Yep, it is possible.  You could have blown the power amp in the head unit.  Another lesson in the "always disconnect the battery before working on any vehicle power circuits" category.
I suggest you try disconnecting your amp and see if the HU will come back on before you go any further.  You might get lucky.
fj40john
Member - Posts: 17
Posted: November 17, 2004 at 1:13 PM / IP Logged
The amp is working fine, as are the subs. The only parts that don't work are my left side speakers.
The amp is connected to the reciever via the high pass inputs spliced into my rear speaker wires. Could the short have gone through my speakers and fried the left side of my receiver?
DYohn
Posted: November 17, 2004 at 1:23 PM / IP Logged
Could be... or the HU could be OK and it's just a shorted line-level adapter.  Disconnect this from teh speakers and see.  Like I said, you could get lucky.
fj40john
Member - Posts: 17
Posted: November 17, 2004 at 1:50 PM / IP Logged
Just tried disco'ing the amp, and the speakers are still dead.
dxav
Silver - Posts: 314
Posted: November 17, 2004 at 1:56 PM / IP Logged
Did you try hooking another set of speakers to your left side?
Usually, if you cross a + and - from a receiver, it will fry its internal amp, and none of the speakers will work.
Were there any unusual sounds or smells?
DXAV
dxav
Silver - Posts: 314
Posted: November 17, 2004 at 1:58 PM / IP Logged
You don't have a RCA pair out of the HU?
What happens if you connect the lines to the rear speakers up to the amp directly (and don't connect the rear speakers at all)?
DXAV
DYohn
Posted: November 17, 2004 at 2:02 PM / IP Logged
Disconnect the LOC you have connected to the speaker outputs from the head unit.
