resistor values 2000 dodge neon
isus
Copper - Posts: 71
Posted: November 17, 2004 at 7:27 PM / IP Logged
Can anyone tell me what the resistor values are for the lock and unlock functions on the 2000 dodge neon.
thanks
Ty1378
Member - Posts: 8
Posted: November 17, 2004 at 7:47 PM / IP Logged
Lock is negative trigger thru a 1K ohm resistor, unlock is negative thru a 250 ohm resistor. If vehicle has factory alarm, use negative trigger thru a 2.7K ohm resistor for arm/lock, and negative thru a 7.5K ohm resistor for disarm/unlock, use double pulse for unlock.
ty1378
isus
Copper - Posts: 71
Posted: November 17, 2004 at 9:18 PM / IP Logged
I have the factory alarm Sentery system and I tried using a 2.7 k ohm and a 7.5 k ohm and it still wont work correctly.  The factory system wont arm at all.  I was thinking about going off of the lock and unlock wires off of the factory remote keyless entery module under the dash.  The arm/lock wire is ORANGE / black and the driver unlock is pink/black the other door unlock wires are pink/violete.  Do you think I will need to use resistors for this?  is this something I should do?
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
