Hit bump Amp styck in protect
nychris2004
Copper - Posts: 54
Posted: November 19, 2004 at 10:21 PM / IP Logged
The subject pretty much speaks for itself, i have a rofckford 501bd amp and i hit a really big bump and my amp just stopped working. I looked at it and it was still on but it was in protect. I unhooked everything and rehooked everything but it wont go out of protect mode.
ANything i can do??
JVC HU
Rockford 501bd (500 watt rms)
Rockford Hx2 Rf2212 (1)
Kenwood 6969 (4)
---If You Learn Something New Everyday And Teach It To Someone Else, Everybody Would Still Be Dumb As Hell!---
Poormanq45
Silver - Posts: 597
Posted: November 19, 2004 at 10:27 PM / IP Logged
How long did you leave it Unhooked?
AMps have capacitors in them which do not immediately discharge when the power source is removed. Try disconnecting it for about 30minutes. See if that works.
Also, an amp will go into "Protect Mode" if there is a ground fault. Meaning there is a problem with your ground connection(s). Check the ground(s) to make sure that they are still intact.
nychris2004
Copper - Posts: 54
Posted: November 19, 2004 at 10:29 PM / IP Logged
I left it unhooked for like a day and i rehooked up my ground wire too, and another amp worked with it
JVC HU
Kenwood 6969 (4)
jeffchilcott
Platinum - Posts: 2,483
Posted: November 19, 2004 at 11:01 PM / IP Logged
dosent sound healthy, can anyone answer do these amps have internal fuses?
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
xtremsounds
Posted: November 20, 2004 at 12:21 AM / IP Logged
Did you have the amp mounted on your speaker box , check inside the amp the ground points .This requires some knowledge on electronics  , if your not  , dont mess with it  take it to a service shop . A t.v vcr repair shop even could help you out in this case
Wednesday, March 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
