prostart / plymouth acclaim problem
snear
Posted: November 21, 2004 at 3:08 PM / IP Logged
I've attempted to install a prostart remote starter in a 95 acclaim.
When I press the start button, the lights flash on and off 5 times, but nothing else.
Any idea what 5 on/off flashes of the lights means on a prostart remote starter?
Thank You
Scott
draasch
Gold - Posts: 2,172
Posted: November 21, 2004 at 3:10 PM / IP Logged
i think its a code of some sort......do you have all of the safety wires hooked up right????
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
snear
Posted: November 21, 2004 at 4:11 PM / IP Logged
I think I have all the wires hooked up right, although, since it does not work, I am less than confident at this point.
draasch
Gold - Posts: 2,172
Posted: November 21, 2004 at 4:23 PM / IP Logged
can you send a link or post the wiring info for the unit????
we will check it out.....
Good Luck
David
Ace Security
813-376-9778
Tampa
snear
Posted: November 21, 2004 at 6:44 PM / IP Logged
Thanks for the offer.
I was able to program the remote, once the unit was wired up, but I get an error code (lights flash on and off 5 times) when I try to start the car with the remote.
I used the wiring chart posted on this site for 95 acclaim.
The wiring instructions from the starter are at:
http://ca.geocities.com/snear@rogers.com/
Scott
TJ92Civic
Copper - Posts: 161
Posted: November 21, 2004 at 6:56 PM / IP Logged
Hi, do you have the page that tells you what the codes mean?  My first guess, would be that you didn't program the tach?  Some starters you have to program in the tach for it to work.  Good luck!
tim
snear
Posted: November 21, 2004 at 8:59 PM / IP Logged
Thanks.
When I looked at the tach programming section of the manual, it says that if I am in Mode II (which I must have put myself into when trying to program the remote) and I haven't programmed the tach, then the car will not attempt to start, and the light will flash 5 times.
I'll try programming this thing properly tomorrow, and hopefully everything else is fine.
Thanks 12 VOLT!
Scott
snear
Posted: November 22, 2004 at 9:17 PM / IP Logged
Hurray, it starts.
Thanks Guys!!!
Monday, April 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
