Kenwood CD Changer
sparkyboy
Member - Posts: 15
Posted: November 21, 2004 at 4:11 PM / IP Logged
Hi Folks
I have just installed a Kenwood KDC-W4527 CD/Radio head unit and i would like to connect my origonal 10 disc Changer (KDC-C603) to it.
The cable that is attached to the 10 disc changer fits in to the rear of my new unit but it does not work.
Does anyone know how i can get this to work as it works ok if i connect the old head unit back up to it !!!.
Cheers Dan
OOOHH wheres that smoke coming from
dedlyjedly
Copper - Posts: 94
Posted: November 22, 2004 at 5:04 PM / IP Logged
just a thought, some kenwood changers have a protocol selector switch under where you insert the magazine behind the door.  it shoudl have two options "o" and "n" try that in different positions.
also, turn your deck on and off a couple of times after initial connection is made.  this may help it "boot up" properly
MECP certified, 5yrs experience, you probably otta listen bitch!!
sparkyboy
Member - Posts: 15
Posted: November 22, 2004 at 5:25 PM / IP Logged
Hi dedlyjedly
I will have a look later and let you know....if i you dont hear from me again i might have hit the self destruct button Kenwood CD Changer -- posted image.
Cheers Dan
sparkyboy
Member - Posts: 15
Posted: December 06, 2004 at 5:20 PM / IP Logged
Hi dedlyjedly
Sorry i took so long to reply been verrryyy busy
I have had a look at the changer unit and there is no button that i can see Kenwood CD Changer -- posted image. if you have anymore info i would be happy to hear it
Cheers Dan
